Cookie Preferences
close
Setting up a rule for opt-in in Trengo
Article Summary
Was this article helpful?
By integrating Klaviyo with Trengo, you can automate processes in Trengo, based on triggers in Klaviyo. In this series of articles, we’ll show you how to have your customers opt-in (and opt-out) for e.g. your WhatsApp newsletter in Klaviyo.
After you’ve enabled your number in Klaviyo, it’s time for a rule that communicates the opt-in to Klaviyo. Below you'll find a video explaining how to set up the rule for opt-in in Trengo (from 01:59).
Follow the steps below to set up a rule for opt-in in Trengo. You can also use the steps below to set up your opt-out.
1. Make sure you already have an approved WhatsApp template, in which you ask your customer if they’d like to opt-in. Enable your customer to answer using buttons, or the rule you’re going to set up next will not work consistently;
2. In Trengo, navigate to Settings > Automation > Rules, and click the ‘plus’ icon, or ‘Add rule’;
3. Set up the rule as follows;
1. Name: Enter a suitable name for this rule.
2. Active: Leave this toggle enabled.
3. Channels: Select the WhatsApp Business channel on which the template you’ve created is active.
4. When: Set this to ‘Inbound message is received’.
ℹ️ You can leave ‘Sort order’ empty.
1. Conditions: Set Message body > Equals to the text of the button you’re customer would use when agreeing to receive your messages. In this case, it would be ‘Yes, I would!’, according to the template given as an example above.
2. Actions: Choose ‘Send Opt-in to Klaviyo’ and enter your site ID.
ℹ️ This site ID can be found by navigating to Klaviyo > Account > Settings > API Keys, under ‘Public API Key’.
After clicking ‘Save’, you’ve now successfully created a rule that lets customers opt-in (or opt-out) to e.g. your WhatsApp newsletter. Finally, it’s now time to check in on the customers in Klaviyo that have opted-in for your automated messages.
👈 Enabling your number for opt-in in Klaviyo
Confirming an opt-in in Klaviyo 👉
Last updated:
September 26, 2023
